I was under my car this weekend replacing a broken tie rod end. I pulled loose a control arm from the cross member to see if the ball joint was good. They're decent, no excessive play. But the bushing had some cracks in it.
My question is, Can the bushings be replaced, like on the thrust arm?
YES
The other thing is, I have a set of Hamburg Technic lowers that I got from FCP. What part fails on them, the ball joint or the bushing?
BOTH< THE BUSHING OR SAY 5 SETS OF BUSHINGS WONT LAST AS LONG AS THE BALLJOINT, AND THAT DONT LAST MUCH LONGER THAN 20K
