Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Anybody beside BillionPa use Iridium Spark Plugs?
    May 2006
    NH
    Default Anybody beside BillionPa use Iridium Spark Plugs?
    Seems a couple of us report use albeit with apparent satisfaction. Any furthur developments ?
    1995 540i Manual build 1/95
    Sep 2006
    Just ordered some , let you know in a few days.
    Aug 2006
    Europe
    What's your verdict on the plugs?
    Default I've put them in at least a dozen cars now
    including one of my own. No problems and they seem to work well.
    Bay Area, CA
    I have the denso iridium's, but haven't had time to put them in yet. Soon, very soon.
    www.KaRealtySF.com
    Albuquerque, NM
    I ran the original Denso Iridiums in my Toyota 4.7 V-8 for 100k miles and they looked to be in very good condition when I replaced them. I did remove them at 31k to put a slight bit of anti-sieze on them so they would still come out at 100k. I replaced them with the same plug. Autohaus AZ had good prices. I got mine at our local Checkers for about $1 more. Do not try to gap them, the tip is really skinny & is harder than a feeler gage and can dig in and snag and snap the tip off. They should come with the correct gap for your engine. I'm thinking iridiums should do very well in most modern engines as long as there is a direct part number for a given application.
    gale
    Aug 2006
    Europe
    Apart from their longevity, are there other benefits such as significantly reduced fuel consumption and perhaps some extra oomph?
    USA
    yes.
    USA
    well, not significant fuel consumption. if you make use of that extra oomph, then the fuel consumption will go up. there is only about a percent or 2 extra torque, but the more efficient electrode design smooths out the curve.
    TC535i Guest
    I use em in my supercharged 318, cuz it's the only plug I can get in a colder heat range than stock. Happy with them there, but I like stock range replacements in my stock cars.
  1. Who sells the chepest Denso Iridium spark plugs?
    Last Post: 03-05-2008, 08:00 PM
  2. Iridium plugs, IHKA swap, other stuff...
    By Montreal525 in forum 5 Series BMW
    Last Post: 11-10-2006, 12:04 PM
  3. ddenso/ngk iridium spark plugs and m50 engine
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 07-23-2006, 07:23 PM
  4. spark plugs
    By diamond777 in forum 5 Series BMW
    Last Post: 05-28-2006, 04:05 AM
  5. Spark Plugs
    Last Post: 12-29-2005, 04:06 AM
