Results 1 to 4 of 4
Thread: Ruville & SKF quality parts?
    Lexington, Kentucky
    Default Ruville & SKF quality parts?
    Are Ruville tensioner shock & SKF AC pulley quality parts? I was sent this stuff instead of Febi. Both parts are made in Slovakia.
    Not sure if I should send it back. Invoice even stated Febi. TIA
    Benneton (United Colors of)
    i would only send it back if the items you were sent werent cheaper than the febi. SKF was the first bmw guibo manufacturer, IIRC, and ruville is part of the LUK and FAG groups (though i've never used any Ruville parts personally). would worry about it only if you were concerned about febi parts being made in slovakia.
    USA
    SKF is supposed to be better than Febi parts, not sure about Ruville, although FAG is generally a lower priced "alternative" (not as good?) to SKF for wheel bearings.
    Lexington, Kentucky
    BMA sent the parts. I decided to keep based on Patrick's comments and Ryan's post. Even so, I am not sure of the quality of any parts anymore. For example, the last Febi AC pulley lasted only 45,000 miles.
  1. Replies: 4
    Last Post: 01-05-2006, 10:25 AM
  2. Anyone vouch for quality of "LUK" parts...?
    By RobPatt in forum 5 Series BMW
    Last Post: 01-01-2006, 04:55 PM
  3. Used driveshaft quality?
    Last Post: 10-17-2005, 11:01 PM
  4. Rondell Wheel Quality?
    By CoolDee in forum 5 Series BMW
    Last Post: 02-12-2004, 09:23 PM
