Another question: How to remove the hose connecting throttle body and brake booster. Damn its so hard to get that rubber tube out of the metal tube.
Arun
I am trying to remove the intake manifold with the help of this link
http://www.bimmer.info/forum/showthr...old#post122061
I can not figure out where the input and return fuel lines are there for the fuel rail
Please help
Arun
530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
Arun
I found it easier to remove the fuel lines from the chassis instead of the fuel rail. The lines themselves are connected at the rear of the engine to the fuel rail.
Thanks Brosher
Follow the fuel rail back towards the firewall (either side) -- the lines meet at the furthest point back, from below. The fuel rail is symmetrical, so the other line (return or send, whichever hasn't been removed) is at the exact same spot on the other end of the rail. I use a pair of needle nose pliers to work the rubber lines from the metal ones, but sometimes the rubber lines will disintegrate and need to be replaced anyway.
Yeah, that's what I did. I cut the return line and just replaced the whole thing. It is a bear to get to.
Input line is on the driver side, return is on the passenger side. Ramon's picture shows the rear of the intake on the passenger side (return line).
'95 540iA ~212k
Hi Ramon,
Thanks very much for the pictures.
What is the purpose of torn hose in the picture.
http://rides.webshots.com/photo/2227...47009931gefMNF
I too got it torn while removing it. How do I replace it. Do I have to get the whole plastic tube and hose? or is it easy to just clean the disintegrated hose and replace that alone. I would like to know what you did.
Arun
The torn hose runs from under the throttle body to the power booster unit.
It's tight under there, so check the clamp orientation when you reassemble;
It's torn cause I had to grab it with a vise grip. Rubber was very brittle; not even pliable.
Check realoem. I'm not sure 'bout 530 plumbing.
I replaced all rubber and gaskets from the intake manifold on up. Injectors were refurbed too. Parts were from BMA.
Ramon
Originally Posted by Alpinewhite
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
