No, Scott. But you will need one of those suction pumps to do it. The fill and drain plugs are a few inches apart, one slightly higher than the other, on the left forward side of the 6-sp.
Cheers,
Duey
Do you have to take that whole thing off to get to the transmission? thanks
95 540 six speed, Rondell 58 wheels, nothin else special
79 911 SC - pea soup green
Cheers,
Duey
1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
Thanks Duey. I was looking for the 17mm hex sockets that Bentley shows. Glad I spent the afternoon looking for one. I'll be returning that later in the week. Plugs were in so tight I had to use my foot to loosen them. I just used a tube that attaches to the mobil 1 bottle and squeezed real hard. worked. Made only a little mess relative to some of my bigger messes
The first time I changed the fluid, I found the drain right away but couldn't find the fill (although I was staring right at it ) Mine were tight as well.
I find the bonus to the suction pump is the ability to also clear all the old oil out of the bottom of the filter cannister/holder that doesn't otherwise drain out.
Cheers,
Duey
