Results 1 to 7 of 7
Thread: Groaning power steering part 2
    Mar 2004
    Austin, TX
    Default Groaning power steering part 2
    I posted about this about 6 months ago. It's a '90 525 and I would get a groaning noise from the power steering, especially at low speeds. The fluid was foaming quite a bit also.
    Today, I finally got around to putting in a new tank. I bled the system several times with the wheels off the ground. Although a bit better, I'm still getting a roaning noise.
    Any suggestions? Hoses? Pump?
    BMA has the seals to rebuild the power steering pump. Worked well on my 535 pump.
    erased due to slander
    The sounds you describe I believe are the pump cavitating which concurs with the foaming.
    Since fluid level is okay and you have bled the system look for another source of air into the system like a bad seal or hose connection on the suction side. Any visible leaks of course are the obvious starting point.
    A severe restriction can also cause the noise, like a collapsed hose.
    You mentioned a clogged screen in the resevoir. Are you talking about the dished screen under the filler cap? How did that get clogged?
    Mar 2004
    Austin, TX
    Ross, thanks for the reply. I was assuming the screen in the old tank was clogged. It may not have been since changing it out didn't solve the problem. I will clean everything up and keep an eye on it to see if I can determine where the leak is coming from.
    The noise sounds like it is coming from the pump area, so I'll pay particular attention to that. The whole assembly was so wet, it was hard to tell where it was leaking from.
    Which side is the suction side, the big hose?
    Thanks again
    yes, big is suction, small is pressure side.
    Quote Originally Posted by Mr. BILL
    Mar 2004
    Austin, TX
    Thank you
    I had the groaning noise too, it was my water pump bearings goin out.
  1. Power steering cut out
    By stx133 in forum 5 Series BMW
    Last Post: 08-19-2009, 06:41 AM
  2. power steering
    By allerston in forum 5 Series BMW
    Last Post: 07-08-2008, 01:15 PM
  3. Power steering groaning noise
    By Mr. BILL in forum 5 Series BMW
    Last Post: 11-29-2006, 11:24 PM
  4. Steering play, part II
    By Interceptor in forum 5 Series BMW
    Last Post: 11-02-2005, 02:56 PM
