Results 1 to 8 of 8
Thread: locks wont open, need help
    Jun 2006
    southaven miss.
    Default locks wont open, need help
    went thru the search, tried the emergency unlock, wont open, not real good with electrical, if i use the trunk method can someone explain what i hook up, i really dont understand polarity, do i jump it from another car using cables?, please be detailed as im kinda stupid in this area, thanks
    Aug 2006
    Quote Originally Posted by barry 90 525i
    emergency unlock is a mechanical operation, it is designed to work with no power - i cant believe that its failed on both doors, try it again after double checking the manual
    Jun 2006
    southaven miss.
    Default tried it over and over, no good
    saw in older post that several others couldnt make it work either, im really stumped, saw in a post from shogun that in a wreck something makes the locks open, does anyone know how?, i dont want to break a window!
    Nov 2006
    Mid-Atlantic, USA
    Read the manual and try it on both front doors since they changed to the passenger door very early in the E32/34 production. I've never had it not work. The emergency unlock in an accident requires battery power and an impact sensor to operate the locks. I believe the trunk method was simply to supply a 12v power supply to the trunk light wiring which should power the car enough to open the doors with the normal unlock-with-key method. Never tried it though. Good luck.
    Aug 2006
    [QUOTE=BMWCCA1]The emergency unlock in an accident requires battery power and an impact sensor to operate the locks. QUOTE]
    i wasnt refering to the crash sensor, incase my previous post gave the impression it was - just the mechanical procedure for opening the doors with no power
    Nov 2006
    Mid-Atlantic, USA
    Quote Originally Posted by billy
    Right, billy, but Barry was asking about the "wreck" mode, which is why I mentioned it in my reply. That's all. It won't work without a battery, either, but I agree with you; the doors should work with the key, regardless.
    Aug 2006
    Default a strange coincidence
    Quote Originally Posted by BMWCCA1
    as luck would have it, my car had the battery disconnected over the weekend....i locked it with the remote which double locks it then i disconnected the battery...i couldnt use the manual unlock procedure - which is a procedure i use all the time as im always working on something - so i know how to do it
    so i guess bottom line is if you have deadlocked it first, you cant use the manual unloock procedure...although i checked the manual and it doesnt say you cant...
    the way i managed to get in is because in the boot, i have wired a cigarette socket into the boot for a search light, which jumps into the trailor hitch wiring, which has a thick red perm + 12v wire - i just connected a second battery to this, which put power into the system and i unlocked it with the remote as normal...
    Jun 2006
    southaven miss.
    Default talked to a bmw service adviser
    he said the emergency unlock dosnt always work, he told me to try the starter method, so i hooked up the jumper cables and was able to unlock the car. thanks to everyone for there help
  1. Glove box wont open :(
    By freerider in forum 5 Series BMW
    Last Post: 06-19-2010, 01:04 AM
  2. Hood on BMW e34 wont open.?
    By Inphinity in forum 5 Series BMW
    Last Post: 05-25-2008, 11:30 AM
  3. My locks wont work!
    By justinp95 in forum 5 Series BMW
    Last Post: 02-14-2007, 10:17 PM
  4. Door locks wont stay locked
    By Bimmer93 in forum 5 Series BMW
    Last Post: 06-06-2006, 04:42 AM
  5. Why wont my blasted locks sync?!?!?
    By CrimsonBrian in forum 5 Series BMW
    Last Post: 01-19-2005, 12:16 PM
