Results 1 to 2 of 2
Thread: Re: Slightly ackward idle issue
    Agoura Hills, California
    Default Re: Slightly ackward idle issue
    So i ended up picking my oil pressure light problem by just playing with the sensor a little bit. The light is gone now. My oil leak has improved since i poured in a engine sealer, and the tranny noise has disappeared. So this weekend I finally finished my interior and doing all my little stuff on the car. I cleaned the battery terminals and put some belt dressing on the belts from the bottom. The belt dressing is ment to just condition the belts so they last a little longer and dont squeel and stuff. Anyway, since i did that now though, the idle is kinda acting up. Maybe its a seperate issue.
    The car usually idles around 900, which i assume is half normal. Now though, when i hit the gas or am driving and then stop at a light, the car holds the rpms around 1400k for about 5 seconds and then drops back to its normal 900. This is without a/c or anything in the car running. I already checked for an intake leak and i replaced the intake manifold gasket about 10k miles ago. SO what could it be? Is it the belt dressing maybe (causing something to slip a little now so the engien is countering by turning up rpms)? Leak? MAF? Thanks guys
    1990 BMW 525i m20 SOHC 5-speed 140k miles, black on black, stoc
    http://www.born-today.com/Today/pix/tyson_m.jpg
    MAN WHAT?!?!...
    Everyone has to go on U-Tube and watch mike tyson interview
    Aug 2006
    Boulder, CO, USA
    Clean out the ICV and throttle body, those would be the first places i'd check.
  1. Idle issue - Chapter 3
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 11-17-2007, 02:58 AM
  2. another m20 idle issue
    By bmwrp8 in forum 5 Series BMW
    Last Post: 11-05-2007, 11:31 AM
  3. Slightly terrifying starting issue (M30)
    By J.DeFeo in forum 5 Series BMW
    Last Post: 03-31-2007, 03:16 PM
  4. 535 Idle issue continued
    By wjbell in forum 5 Series BMW
    Last Post: 03-29-2007, 12:21 AM
  5. Fixed Idle issue
    Last Post: 06-29-2006, 02:12 AM
