Results 1 to 10 of 11
Thread: ATF for gearbox ?
    Default ATF for gearbox ?
    '88 525e Getrag box? ATF for winter? REALLY stiff until warm.
    What do you guys think?
    Dec 2005
    Brisbane Australia
    whats the recommended, I put EPX into my old 528i's gear box it has additives to help low temperature shifting and it did help the low temp shifting, I don't know about ATF though you could even use engine oils "theoretically". but I am not sure how the engine oil additives would affect the synchros.
    Don't know what's recommened. The book for my '89 says non-hypoid 80w gl-4 or single grade engine oil 20 to 40w.
    This is for an E28 I sold to a nice kid who is now freaked at how stiff it is in the cold(0f) and looking for advice.
    USA
    if you want good ATF, pick up some Redline D4.
    I just bought a car with Redline in it and it's stiff even when warm.
    Dec 2005
    Brisbane Australia
    hmmmmmm its an interesting dilemma, Single grade engine oil? weird man perhaps try some thick engine oil like a 20W-70 or something. by the sounds of it though ATF would be waaaaaaay too thin (isn't it 10W or 5W)
    I've run my 525 with a ZF (ATF-Oil!) in Canadian winters using Mobil 1 synthetic. I have no complaints, but then again, i baby it until its warm
    Dave M
    Dec 2005
    Brisbane Australia
    lifetime fluid what a crock of s**t, typical BMW bastards couldn't care if you had maple syrup in your gearbox so long as it doesn't break before the warranty is up.
    OT: FYI for ZF S5-310 transmissions "The recommended long-life oil for S5-31 transmissions is ESSO MTF LT1 (BMW Part # 83 22 9 408 942).
    Dexron III can also be used, but is not recommended as long-life oil (see also ZF lubrication list TE-ML 11)"
    Notice how ZF says "long-life" not "lifetime"
    taken from this document
    but thank you for the info Bill, as usual very interesting.
    USA
    redline D4 and redline ATF arent the same thing.
    im using a 50/50 mix of D4 and B&M TrickShift synthetic. a year so far, very nice combo.
  1. X5 Gearbox in an e34 540??
    Last Post: 07-06-2009, 05:21 PM
  2. M60 gearbox on M62
    By Jan in forum 5 Series BMW
    Last Post: 07-21-2007, 08:11 AM
  3. Hot Gearbox
    By pfmc24 in forum 5 Series BMW
    Last Post: 06-10-2007, 12:47 PM
  4. Gearbox
    Last Post: 06-27-2006, 09:28 AM
  5. Which gearbox do I have
    By datart in forum 5 Series BMW
    Last Post: 03-29-2006, 07:21 AM
