Results 1 to 5 of 5
Thread: Heating Issues - Any thoughts?
    Nov 2006
    Default Heating Issues - Any thoughts?
    I've got lots of heat but only on the highest temp setting. (Fans works fine) It seems that the temperature controls don't properly regulate the output temp. of the vents. I was initially thinking it could be the heater valves but from reading past posts it seems they normally fail in an open position (i.e. no heat) I have plenty of heat just no control of it other then Full on or Full off. Ideas? Similar experience? Thanks
    1992 525i Touring M50 5spd Manual 230k+ miles - SOLD:-(
    Heater valves can get stuck in any position.
    But:
    By setting it to full high with the click in the setting or on full off, the power to the valves is interruped = valves are fully open= they move in case of your car.
    So it is something in the control panel, or the temp sensor behind the control panel is out of order or completely dirty.
    http://web.archive.org/web/200208130...t/acc_drt1.jpg
    On my website I have about 52 pages IHKA training program for technicians, 2.09 MB, but it is in German.
    Nevertheless, have a look at it
    http://www.e38.org/e32/klimaautomatik.pdf
    Mar 2004
    NSW, Australia
    Its always a good idea to post your profile!
    It might be the electronic switches you have on the dash board. They might not probably sending the right signal to the heating system to work.
    I LOVE BC CANADA
    Lexington, Kentucky
    Noticed the little grill/opening beside the heater dials was "fuzzy" looking this morning. I suspect there is plenty of dirt inside. What is the best way to clean the vent and sensor. I will use my shop vac to start.
  1. Car not heating up enough
    By CrimsonBrian in forum 5 Series BMW
    Last Post: 02-21-2011, 06:13 PM
  2. Replies: 16
    Last Post: 01-25-2008, 02:47 PM
  3. Over Heating M30 3litre
    By cliffybabe in forum 7 Series BMW
    Last Post: 11-06-2007, 08:53 AM
  4. heating problem
    By wappy in forum 5 Series BMW
    Last Post: 11-23-2006, 03:40 PM
  5. 540 v8 over heating
    By dbou in forum 5 Series BMW
    Last Post: 08-25-2006, 08:42 AM
