Results 1 to 3 of 3
Thread: Power Steering Pump Leak
    Nov 2006
    York, PA / Penn State
    Default Power Steering Pump Leak
    Well, I came home today to notice a nice pile of petosin on the floor in my garage. I jacked up the car and got underneath to check it out and the Power Steering pump appears to be leaking from right behind where the pulley attatches. Does anyone here know if the "gasket kit" includes the necessary seal to fix this issue? Also, am I wasting my time since I am installing some Konis next week and will be eliminating the SLS? Any help would be appreciated.
    USA
    well, unless you dont need power steering, i would get it fixed. the SLS just uses the common reservoir because pentosin is so good.
    i have not seen any kind of gasket set, but that doesnt mean one doesnt exist.
    Nov 2006
    I found a gasket kit for the stock pump on realoem for around 50 bucks. I have no clue as to what it consists of but I am really hoping it should do the trick.
    I worded that wrong as well. I meant should I delete the M5 pump in favor of the 535 pump.
  1. power steering hose leak
    By Renman in forum 5 Series BMW
    Last Post: 12-23-2008, 05:17 PM
  2. Power steering leak at banjo
    Last Post: 01-11-2008, 11:46 PM
  3. Power Steering Leak
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 03-06-2007, 04:11 PM
  4. power steering pump
    By innes in forum 5 Series BMW
    Last Post: 10-14-2006, 09:09 PM
  5. Help - Power steering fluid leak
    By Scott E in forum 5 Series BMW
    Last Post: 07-10-2004, 11:58 PM
