Its telling you the oil level in the engine needs checked (it is low) and to look in the owner's manual for instructions.
"Bitreibsanliets."
"Oelstand Motor"
These two apperered after I shut the car off after a three-hour Interstate jaunt. What are they and what the hell do I do?
Thanks!
Thanks!
I can't get my car to change to German... I want to but maybe I'm doing it wrong...
EuroLux:. Private Detail
Denton,
why do you not change to English? Easy
Changing the OBC language:
The OBC language of the car will sometimes reset itself to German. To change it to whatever you like try this:
1. Turn the ignition to position 1.
2. Hold the CC button down for 10 seconds. Then the next language will appear.
3. Repeat this procedure untill you have the desired language.
The available languages are: English UK, English US, French, German, Italian, Spanish
Yeah, thanks Shogun. I changed it to German because I thought it was cool, but didn't think about situations like this.
I'll keep your reply as a future reference to change back to English if another code thingy pops back up.
I'll add a quart and see where it is on the dipstick...
I use this, http://dictionary.reference.com/translate/text.html.
It doesn't pick-up everything but it helps.
This works sometimes too,
http://www.langtolang.com/
Spasso
530iT, 525 5-speed , 328is.
this one is better by Kiessling racing, especially for cars
http://www.kiessling-racing.de/dictionary_de.htm
you can switch from English to German on top
Thanks. I knew there was a better one out there.
Spasso
What's the CC button?Originally Posted by shogun
-Mike
