Remove and replace the OBC (Bentley describes the process). The action of R/R should help remove oxidation from the terminals.
It is more likely that the problem is with the plug-in connectors on the rear of the cluster. They cause more problems than the OBC.
Although just removing and replacing will help clean them, STABILANT 22 will help the fix last longer. http://www.stabilant.com
Originally Posted by CrimsonBrian
