Carefully pry off the middle trim peices, then the trim pieces that wrap around the corners will slide off (after disconnecting the running lights). This exposes the four nuts that hold each bumper in place. Remove them and...viola!
When you replace them be sure you have all the slotted pieces fitted together before yu tighten it all down.
