I can vouch for the kit as I was around during its development. Everything Bruno does associated with these cars is first rate. The remote canister kit is no exception.... comprised of only high quality parts manufactured to precise tolerances. The most noteable advantage is the oil bath is captured by a conventional thread-on disposable oil filter cannister therefore there is always an immediate oil supply at start up. There is no check valve to fail over time. Installation is quite simple...one of the easiest jobs you can perform on these cars...would rate it 1 out of 5 wrenchs for removing your old cannister and replacing it with a Racing King remote canister. If you need an oil cannister replacement which is quite common on an aging M-30, this is a very practical and cost effective option.
HTH,
George
90 735iL/149k
