Results 1 to 5 of 5
Thread: wheel sizes
    Apr 2004
    Default wheel sizes
    I'm considering buying a set of 16 or 17 inch alloys on ebay to replace my standard 15s.
    Which other models' wheels will fit the e34? (eg e39, e46?)
    I beleive some may need spacers
    Honolulu
    Default No 3 Series Wheels
    You'll need 20mm of spacer.
    look for E34, 32, 31, & 39 (with hubcentric rings)
    http://www.bmwe34.net/e34main/upgrad...ls_upgrade.htm
    Sedro-Woolley, WA USA
    Quote Originally Posted by Blitzkrieg Bob
    What he said. Spacers just dont work well. Wheels that fit an e39 work just fine on an e34, with hubcentric rings.
    I had good service and prices, with lakeshore wheel and tire- got a set of 17 inch M5 reps, with pirelli p6's mounted, Roadforce ballanced,all lugs, center caps and centric rings ,shippped for total of $1125.
    If you put on 18" wheels, hope your road surfaces are smooth and have no potholes- pretty easy to prang a rim when your tires are not much thicker than rubber bands- and if your car is lowered, the ride will be rougher than a cob.
    Aug 2005
    West Portland, OR
    Quote Originally Posted by karl1171
    DON'T USE 3 SERIES WHEELS, I USED THE SPACERS! Not only do they look sucked in, they don't drive nice and under any rigorous driving they couod pop right off! :-O!!!!
    So, take my advice, don't be stupid like me.
    Besides, 5-series wheels look so much better altogether.
    EuroLux:. Private Detail
    Jan 2007
    All BMW 5/6/7/8/Z8 wheels are interchangable and have the same specs EXCEPT the E39 5 series hub.
    They all have:
    • 5x120 wheel bolt pattern
    • 11mm-32mm wheel offset range
    • 72.56mm wheel hub (except the e39 5series which has a 74.1mm hub...hub centric rings are required)
    All...even includes the new 5/6/7 models.
    The BMW 3/Z3/Z4/X3/X5 models have wheel offsets that are too high (35mm-48mm) and would require wheel spacers (just as others have mentioned. EXCEPT the e30 M3 & E46 M3...their rear wheel offset is approx 25mm...so you could conceivably mount these rear wheels (only) on all four corners.
  1. BMW wheel and tyre/tire geometry/sizes explained...
    By genphreak in forum 5 Series BMW
    Last Post: 12-16-2006, 03:47 PM
  2. About Wheel Sizes
    By granit_silber in forum 5 Series BMW
    Last Post: 09-25-2006, 06:17 PM
  3. Wheel nut sizes
    By Jay 535i in forum 5 Series BMW
    Last Post: 02-17-2006, 04:34 PM
  4. Badge sizes.
    By Rob in forum 5 Series BMW
    Last Post: 10-23-2005, 11:49 AM
  5. tire sizes
    By Hans Stuck in forum 5 Series BMW
    Last Post: 04-23-2004, 01:42 AM
