Clockwise, i.e., opposite to the usual direction for loosening a bolt. A sharp wrap with a heavy hammer (a 5lb sledge is good) on the handle of the wrench will normally loosen it. Pushing on the wrench will just make the belt slip.
I borrowed a 32mm wrench a friend. Facing the car, should I turn the wrench clockwise or counter clockwise? I tried both but the belt just keep moving not the 32mm bolt. What am I doing wrong?
Thanks.
(SOLD) 92 525ia M50 | NGK plug | JVC AR560 | EAT chip | California
1997 535i V8
I tried hitting the wrench handle clockwise with a hammer several times. no luck. Just sprayed some WD40 to the bolt. Will try gain soon. Thanks.
Try wedging a long screwdriver in the water pump belt/pulley, holding on tight, and giving the wrench a jerk with the other hand. I didn't think mine was going to come loose either but eventually it did. Also, cursing loudly, preferably in German, has the same effect as PB Blaster or WD-40.
You'll probably need one of these:
http://www.bavauto.com
Part Number Description Price
115050 Tool - Fan Pulley Holder $39.95
Still can't loose that thing. Have been cursing loudly volkswagan and Heineken (the only German words I know).
clockwise when standing in front of the car looking into the engine bay?
1992 BMW 525iT (sold)
1998 V70R
Yes, I might need it. Thanks for the info.
i always use two big pairs of water pump pliers against each other, one for the nut and one for the pulley, works every time, don't forget that it's a left hand thread
Bigger hammer needed, and a ringing whack on the wrench handle like you really mean it.Originally Posted by brick8
1997 535i V8
