you covered most of the bases, thanks for the searches. I would recommend a computer reboot which will set all codes gone and you will have fresh to start with. If the codes are never reset the same issue will traspire even tho you replaced the failing items indicated. Wait after you reboot the computers and post again, hopefully your troubles will go away.
good luck and the best.
