Results 1 to 4 of 4
Thread: speaking german on dash 89 525i
    May 2006
    Default speaking german on dash 89 525i
    How do the heck do I get my dashboard to change back to english. It is a 89 525i. The dealers don't know how to do it and neither does the customer service of BMW of NA. I have 4 different german words telling me something is wrong and I don't speak german. What the heck, can anybody help out there?
    Dennis
    Dunlap Illinois
    Turn the ignition switch to the "on" position, press and hold the button beside the bottom of the tachometer for 10-20 seconds, the languages should start to scroll, if you miss it keep trying, it'll come around again. There are several to choose from....
    JR
    Dec 2006
    Melbourne, Australia
    Try turning off the car, then hold onto the Check Control button (right button on the dash), then switch the ignition to position 1. Keep holding the button for 10 secs or so and the dash will allow you to change languages (press the check control button to scroll through).
    http://www.m5board.com/vbulletin/arc...hp/t-6767.html
    EDIT: if that still doesn't work, write down what it says in German on your dashboard and post back in here, we'll probably be able to figure it out for you.
    If you cannot change it, just post the German here and I can translate it.
    In case that happens often, you may need to change the capacitors
    http://bmwe32.masscom.net/johan/dash...dash_caps.html
  1. My 535 is speaking german
    By rockin1978TA in forum 5 Series BMW
    Last Post: 07-08-2010, 05:41 PM
  2. No Dash Lights On My 89 525i
    By ShawnSki23 in forum 5 Series BMW
    Last Post: 11-05-2005, 08:54 AM
  3. Replacing the In Dash AM/FM on 1993 525i
    By blackcat1134 in forum 5 Series BMW
    Last Post: 03-12-2005, 06:59 PM
  4. Dash displays in German ??
    Last Post: 06-19-2004, 08:14 AM
