Results 1 to 3 of 3
Thread: expantion tank leaks
    arkansas
    Default expantion tank leaks
    My expantion tank leaks!! It is not cracked. Is there a way I can replace the seals. Has anyone done this to there radiator before.
    Derbyshire, UK
    Yup. Undo the two screws on the plastic plate above the tank, pry out the tank, change the o-rings, lubricate them with antifreeze, push the tank back in, and reinstall the plastic plate.
    1997 535i V8
    Hayward CA
    first try replacing the radiator cap. i went through 8 months with radiator problems. replaced hoses, expantion tank was still leaking, even bought a whole new radiator. but then i found a recall on the caps so i replaced it and no problems since. Just try that first.
  1. M30 engine oil leaks
    By Rus in forum 5 Series BMW
    Last Post: 02-27-2009, 12:12 PM
  2. possible oil leaks on M70 engines
    By shogun in forum 8 Series BMW
    Last Post: 06-19-2008, 09:49 AM
  3. Oil leaks and low pressure, oh my!
    By nmwaldron in forum 5 Series BMW
    Last Post: 09-17-2006, 01:59 PM
  4. So, i found some leaks....
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 10-20-2005, 08:33 PM
  5. Vacuum leaks
    Last Post: 04-20-2004, 04:23 PM
