Results 1 to 3 of 3
Thread: Brake Fluid dummy light on dash
    Default Brake Fluid dummy light on dash
    of my 1990 535i now goes on when I turn the ignition OFF?? Does anyone know where to start checking for a problem?
    The fluid level is fine. All that is changes is that the battery died from sittiing a couple of weeks while I was away and I jumped the car. Other than that I have not seen that light on in 9 years of ownership. Thanks.
    USA
    put the battery on a trickle charger, and if its not an AGM battery, check its fluid level.
    Also check that the float in the resevoir isn't stuck and for corrosion on the terminals.
  1. Brake Fluid Light Issue
    By BIGRED in forum 5 Series BMW
    Last Post: 04-21-2008, 12:15 PM
  2. Brake Light, Tail Light, Licence Plate warnings
    By leicesterboy15 in forum 5 Series BMW
    Last Post: 09-24-2007, 05:01 PM
  3. Brake Fluid Light Indicator
    By realness in forum 5 Series BMW
    Last Post: 10-07-2005, 01:19 PM
  4. if brake fluid warning light comes on .....
    By chris540 in forum 5 Series BMW
    Last Post: 02-17-2004, 09:08 PM
