My dealer quoted 2hrs labour for one rear wheel bearing, so I guess even with the special tool it is still a complicated procedure.
BMWe34.net shows a procedure for replacing the front wheel bearings, and it is very simple - you just replace the entire hub. There isn't a procedure for rear wheel bearing problems.
Looking at my Bentley and also the ETK, it appears that the rear wheel bearing replacement is not the same. It looks like the hub assembly has to be taken apart and the wheel bearings, only, replaced. Is this true, or can the hub be replaced and that include new bearings?
The manual makes mention of several special BMW tools to take the assembly apart and replace the bearings. This doesn't appear to be something that a driveway mechanic can accomplish, and I am wondering even if my excellent independent mechanic would be able to do this without the special tools.
This is on a 1991 525i.
Dick Schneiders
Before you commit to a bearing replacement, are you sure it's not the parking brake shoe contacting the drum or the pad dragging on rotor due to a stuck/sticking caliper? I'd also use the suggestion I made in
http://www.bimmer.info/forum/showthr...2705#post12705
This has the effect of extending the halfshaft and making CV joints operate outside their normal range. Probably helps redistribute the grease to some extent also. If noise is CV joint related I would expect this to change the noise if only temporarily.
Paul Shovestul
Originally Posted by Dick Schneiders
It might also be more cost effective to find a low-mileage set of trailing arms from a yard and swap the entire assembly into place. Much easier to replace the arm than just the bearing, and arms from a wrecked '95 would likely be more than suitable for another 40K or so miles.....
As Paul said - check for other problems first. It's not very often that the rear bearings go bad. For all intents and purposes they are "lifetime" parts (i.e. 250K-300K miles without a problem).
Any pictures yet?
--Micah
that it looks as good as the throwing star wheels. It is spring here, finally, and I need to do a lot of catch up repairs on our 4 vehicles.
I promise that you will be the first to get any pics.
Thanks for the suggestions.
Dick Schneiders
Originally Posted by MicahO
Originally Posted by Bellicose Right Winger
I finally got some pictures up, though since they aren't e34's, I don't know who here wants to see
http://www.bimmernut.com/~micah/330iZHP.htm
I should clear 1K miles next week and finally be able to open the sucker up a bit.....
if you're willing to take care of it yerself, and it is indeed the bearing (and its a safety issue) 75 plus parts cost is not too bad
http://www.koalamotorsport.com/services/toolrent.htm
Now I have some options. Hopefully it doesn't turn out to be a wheel bearing issue.
Dick Schneiders
Originally Posted by ryan roopnarine
bearings on was a e24, didn't have any special tools but fabricated the pullers and pushers that I needed..But i also had access to most of the equipment needed to fabricate the tools..
