Results 1 to 10 of 10
Thread: Pretty easy one
    Maryland, Virginia, D.C.
    Default Pretty easy one
    Hi,
    I just have a simple question. You know the automatic gear shift display next to the shift lever- is that supposed to be backlit or not? I can't see it at night and was wondering if that was normal or if I had a bad bulb or the like. Thanks.
    Its supposed to be lit.
    Chris
    95 530I M60, 1975 C-172M
    Feb 2007
    Glendale,CA
    i can confirm this one
    it is supposed to be lit....
    1995 BMW 525i E34 M50B25 2.5L (Non-Vanos) -Automatic Transmission- (w/ Cruise Control & Full OBC) *REBOUGHT!!*
    Feb 2005
    Nowra NSW Australia
    Mine is not lit, Mine displays current gear on the dash. I would not be surprised your 94 to be the same. regards
    Feb 2007
    Glendale,CA
    mine displays in in the dashboard as well, but the gear shift are lit as well...
    OK, so lit is it. Thanks.
    Jul 2005
    Adelaide Australia
    mines not lit and is not backlit its just a piece of black plastic. mie diplays on dash
    kev535i south oz
    USA
    mine was backlit, till i removed the bulb, because i never look there anyway and all it was doing was making my alternator work harder!
    Connecticut
    Quote Originally Posted by BillionPa
    It's only a 1.2w bulb. Do you think the alternator even noticed?
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    Sep 2006
    My A/M switch light burnt out but totally don't care.
  1. Pretty amusing
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 12-18-2006, 01:59 AM
  2. Need a CarFax, pretty please.
    By Torque in forum 5 Series BMW
    Last Post: 11-03-2005, 12:33 PM
  3. You know your bmw svc is pretty useless when...
    By Jason in forum 5 Series BMW
    Last Post: 12-10-2004, 10:58 AM
