Results 1 to 10 of 13
Thread: Help Wheels Issue
    Sep 2005
    Default Help Wheels Issue
    Hi all,
    I just replaced my 15” bottle caps wheels with these style 15” wheels. I am using the same tires that I had on the bottle cap wheels. I am experiencing vibration at high speeds on the highway. When I had the bottle caps on these same tires I never experienced any kind of vibration. The car ran smooth sailing on the highway.
    After doing a search I get the sense I may need hub rings.
    Should I have a wheel balance and an alignment done first before I put on the hub rings? Or will the hub rings resolve this issue without wheel balancing and alignment? Or should I do both?
    I’ve never had this vibration issue until I switched wheels. Please let me know what I should do.
    Thanks!
    89 BMW 525I
    first step is the rings. They hold the wheel centered as the lugs do not, its an interference fit. That should take car of 90%, the next step would be a balance job from a GOOD shop not the local chain store.
    Sep 2005
    I will start with the hub rings. I just ordered a set from tirerack. I hope it works.
    Thanks!
    89 BMW 525I
    Hopefully it will amaze you!
    Quote Originally Posted by realness
    Ann Arbor Michigan
    What size ring did 'ya order? I have the same rims and the same problem,
    SOLD!
    Nov 2004
    I believe it's part # A670...you can click search and use "A670" as the "key word" to verify that's the correct number. If its the correct number...you'll get lots of hits....if its the wrong number...you'll get nothing.
    You will also need to call TireRacks toll free number and speak directly to a customer serv rep to order them. I've never seen them listed anywhere on the website.
    Q
    95 525iT / 97 740iL
    West Palm Beach, South Florida
    I just ordered my rings from Jim @ tirerack - he runs a little promotion over on bf.c and invites people to call him. 4 minutes on the phone on my way home from work and the rings are on their way.
    Sep 2005
    Quote Originally Posted by fujioko
    I called and ordered part #A670 from tirerack yesterday. I believe the size is 74.1od and 72.56id.
    Thanks!
    89 BMW 525I
    Sep 2005
    Default What a difference!!
    I put the hub rings on this saturday. Wow what a difference these little rings made. No more vibration. I still plan on getting the wheel alignment and balance to keep even thread wear on my tires.
    I apperciate the advice!!!
    Thanks!
    89 BMW 525I
    wow better than 90%, damn good reccomendation huh? Now you can enjoy them.
  1. WHEELS! NY/Proximity plz read! Snatch up these wheels!
    Last Post: 09-11-2006, 05:46 PM
  2. Is this an LKM issue?
    By ///Mink in forum 5 Series BMW
    Last Post: 04-12-2006, 05:08 AM
  3. 1994 E34 520i Tourer - Steering Issue And Wheels
    By E34 Touring in forum 5 Series BMW
    Last Post: 03-29-2006, 02:15 PM
  4. A/C Issue on 93 525
    By Lilrobus in forum 5 Series BMW
    Last Post: 07-10-2005, 07:03 PM
