Results 1 to 7 of 7
Thread: Help removing door handle trim...
    Mar 2004
    New Orleans, LA
    Default Help removing door handle trim...
    I have new rubber to put behind the door handle trim pieces, but I am not sure how to remove the plastic trim around the door handle.
    Any help is greatly appreciated!
    BigezVol
    1991 525i, 106k, EAT
    Open each door and at the same level as the door handle on the back of each door is an oblong hole with a rubber grommet in it. Remove the grommet and you will see a lever/latch that secures the outer door handle cover to the outer door skin. Use a long narrow blade screw driver through the oblong hole to move the latch to one side to remove retention of the handle cover. Installation is reverse of the former :-)
    HTH,
    George
    Mar 2004
    New Orleans, LA
    Default I new I bought that Bentleys for a reason...
    Thanks Goerge, found it right after I posted. I sometimes forget to listen to the other side of my brain it think to look at directions.
    Got them installed. They make the door handles look much better.
    BigezVol
    Dallas, TX
    George, can one replace the whole handle the same way?!
    Mine are looking a little ratty. That seal is shot, and needs to be replaced, but I was thinking about just replacing the whole handle. Or is that much more difficult?
    TIA
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    '94 Land Cruiser FZJ-80 202k mi.
    "If I could have back all the time and money I ever spent on cars.......I'd spend it all on cars."
    baton rouge, loserana
    gotta take the door apart, and the handle assy is pricey
    Quote Originally Posted by Super90
    TIA
    Dallas, TX
    Part# for the seals? Last time I asked, I think Patrick at BMA said they don't sell those seals separately. I seem to remember him saying you had to buy the whole handle assembly. Anyone have a part# for just the seals?
    Robert Callaway
    Dallas, TX
    '94 530im 143k mi
    Wellington,New Zealand
    Default the seal and outer trim come together
    my latch slides forward to release the outer trim and dlides back to secure
    Gone but not forgotten
  1. how to remove the outer door handle trim-DIY video
    By shogun in forum 3 Series BMW
    Last Post: 05-07-2010, 07:09 AM
  2. removing the front door handle
    Last Post: 05-17-2007, 01:50 PM
  3. Door handle plastic trim
    By mango in forum 5 Series BMW
    Last Post: 02-22-2007, 11:55 PM
  4. DIY door handle trim replacement
    Last Post: 12-07-2006, 09:36 AM
