a good question...this has been a point of controversy before on the board. Speculation is that even some of the plastic bottle reservoirs on non LAD cars had a filter in the bottom. Perhaps your best bet is to consult the ETK with your VIN no. to learn what reservoir type you have. You also maybe able to tell by measuring the outside depth of your reservoir and compare it to a depth test on the inside of the bottle. If inside depth is less than the overall outside height of the reservoir by an inch or so...likely you have a screen in the bottom.
A very good practice to replace this filter on a higher mileage car BTW.
HTH,
George
