Thread: Will Death be Shifting my Automatic Soon?
    Default Will Death be Shifting my Automatic Soon?
    Here is the car: 1990 BMW 535i Automatic 170,000 miles
    So I had a wierd downshift when i took a turn too fast, so i freaked out thinking something might be wrong. The car drove fine to my destionation, and has been driving fine all along. Well, the only thing i noticed is a wierd shift to 4 gear when i am lightly on the gas. It almost feels like you let the clutch out too soon on a fith gear change. Anyway, I checked the fluid.........It looked bad, very little red. Honestly, mostly brown. The only thing that didn't really bother me was that it did not smell burnt.
    So i am taking the car in next week to get me cruise control servo fixed, and do you think i should have the fluid changed? Now, i know most will go, "you idiot change it", but i do not want to open a can of worms. The car shifts fine now, and is quite smooth. It always has been. I am worried that opening it up might "move" something that would have stayed in place.
    So the shop offers 2 options for the flush; an empty, then refill or a pan drop, filter repacement, refill (this one scares me). Or, i could take option 3, and not do anything.
    Honolulu
    Default Fluid & filter
    will extend the life of a good trans, help a marginal, and kill a failing trans.
    I first changed my fluid and filter a few years back and the shifting smoothed out, now I change it once a year to keep it going.
    Yop may be in luck since it's not burned up yet.
    Good luck
    Doing a simple empty and refill is not much different than removing the pan and changing the filter. You'll change the same amount of fluid either way (~3qts). I'd change the fluid AND filter. Like Bob mentioned, if the fluid didn't smell burnt, your trans might still have a heartbeat. If there is one thing to avoid, it would be a complete tranny flush. HTH
    2nd this. There is absolutely no reason to leave a filthy filter in place, ever.
    The funky operation may clear up with fresh fluid.
    O.k. I think i will have the whole thing taken care of. Should i go syntheic, or leave the dino ATF fluid in?
    Definitely do a complete ATF fluid change... stick with dino for now until you know for sure tranny is okay. Valvoline ATF is good.
  1. Automatic Transmission High RPM Shifting
    By NovceGuru in forum 5 Series BMW
    Last Post: 08-21-2006, 05:38 PM
  2. Manually Shifting W/ Automatic
    By saj3n in forum 5 Series BMW
    Last Post: 08-02-2006, 06:47 AM
  3. Death of a 4L30E automatic
    By George Davis in forum 5 Series BMW
    Last Post: 08-02-2004, 12:55 PM
  4. 5-speed automatic shifting?
    By Bill H. in forum 5 Series BMW
    Last Post: 05-28-2004, 10:12 AM
