Three things. I haven't seen a cross section of a BMW hydraulic lifter, but I believe they are similar in principle to GM and Ford lifters. There is no oil flow thru the lifter. They are pressurized with oil and that oil will stay in the lifter until it leaks out. This could be a very long time so oil inside gets cooked by engine heat. Low viscosity oils should leak out of lifters quicker then high viscosity oils. The benefit of the thinner oils is a higher leakage rate and this should help flush any accumulated gunk out of your hydraulic lifters. Mobil 1 has superior detergents compared to conventional oils. If I had a lifter noise problem, I'd change to the thinnest Mobil 1 oil the manual allows and see it it improves.
It may not be the lifter's fault. Check your oil pressure. Bill R. had a good thread about a gasket on the oil pump inlet that would fail and admit air, and reduce oil pressure. Reduced oil pressure will cause lifter noise.
Make sure it's not injector noise, they can be loud. Put the tip of a long screw driver on the injector, put the handle in your ear and listen to the injector.
Paul Shovestul
Originally Posted by
525iE500
I've searched and read every post on lifter noise, engine tapping, sounds like a diesel, etc etc. and am completely confused.
My 95 525i, automatic, was purchased off lease with 29k on it. It has 133k on it now. It has been serviced regularly at the dealer it's entire life.
It has the tapping noise that sounds like a lifter. The noise comes and goes.
Sometimes it's there at cold start and sometimes it's not. After driving at speed for a while and then coming to a stop its much louder but sometimes it won't be there at all. It seems random to me but generally worse after it's driven.
After searching and reading this board I've come to the conclusion that a less viscous oil such as M1 0w40 is NOT the answer. Am I correct?
I just had an inspection 2 done and the dealer said it was barely audible and no big deal but I doubt they drove the car at speed like I described above and heard it get louder.
Any thoughts, anyone????????????
