Thread: IS this reservoir for pentosin or ATF?
    El Paso TX
    Default IS this reservoir for pentosin or ATF?
    I'm assuming this is the power steering/suspension reservoir, and that it takes pentosin since it has no dipstick, like a normal powersteering reservoir.
    Just wanted to check before I added anything, as well as ask...
    ?!?!?! How the heck do you know it is "FULL" ?!?!?!?
    El Paso TX
    never mind, question answered.
    pentosin chf11s, fill to the bottom of the screen, on cars with hydro boost brakes you need to pump the hell out of the brakes with the engine off to discharge the brake accumulator before you top up the tank to the bottom of the screen
    how do you replace the filter?
    ponders the e31
    El Paso TX
    Took an entire metal can of the stuff. that is one HELL of a reservoir!
    usually sitting in the bottom under the screen a E clip a few springs a spacer and or a nut, generally a shriveled up nutsack looken little hunk-o-**** bout the size of a cat food tin
    ponders the e31
  1. Pentosin Notes
    By MBXB in forum 5 Series BMW
    Last Post: 04-06-2010, 05:01 AM
  2. Where to get Pentosin?
    By ScottyWM in forum 5 Series BMW
    Last Post: 01-12-2009, 08:12 PM
  3. VW PS Fluid - equivalent to Pentosin?
    By Traian in forum 5 Series BMW
    Last Post: 01-09-2008, 02:02 PM
  4. do NOT mix Pentosin CHF 7.1 and 11S
    Last Post: 05-23-2006, 07:07 AM
  5. PS reservoir
    Last Post: 01-05-2006, 12:58 PM
