Results 1 to 3 of 3
Thread: Fuse mayhem = bad connection on battery neg.
    Dec 2005
    Brisbane Australia
    Default Fuse mayhem = bad connection on battery neg.
    I've so far blow 4 fuses in the last month or so.
    here's the tally so far
    2 x rear demister (under hood fuse box 2nd fuse blew within a day so I suspect blown relay so i won't replace fuse until i've checked it out)
    1 x indicator fuse (no problems otherwise)
    1 x parking light fuse left (bulb was blown)
    followed by a hand brake light that doesn't fully go out when the hand brake is put down. (and last night dim hand brake and altenator lights)
    now i have had to disconnect the battery a few times during that period to look at the slip ring (which i have finally replaced), my question is could this be associated with a bad connection on the negative terminal of the battery?
    bad batt connections can cause all sorts of gremlins, I'll bet their all related to it.
    Honolulu
    Default I replaced
    the ground strap between the chassis and the block, the ground cable and terminal, and cleaned the fusible link terminals and replaced the link.
    Did all this because I was experiencing some electrical problems.
    The problems are gone.
  1. E34 fuse list, anybody? I narrowed it down to fuse 20.
    By chapmanw in forum 5 Series BMW
    Last Post: 03-23-2007, 11:43 AM
  2. Name this connection...
    By Macv in forum 5 Series BMW
    Last Post: 10-29-2006, 08:51 AM
  3. battery cale positive fuse
    By pong in forum 5 Series BMW
    Last Post: 04-05-2006, 07:05 PM
  4. Battery drain through fuse 20
    By dwlawson in forum 5 Series BMW
    Last Post: 11-28-2004, 09:24 PM
  5. Battery Fuse : Scenarios on how it can burn out...
    By sheggaw in forum 5 Series BMW
    Last Post: 11-16-2004, 05:52 PM
