Oops, nevermind. I misread the post
whats the dimensions of the rotor screw?
gotta buy a new one since im going to brake mine off, its stuck
any1 got an idea?
gale
http://www.realoem.com/bmw/showparts...25&hg=34&fg=05Originally Posted by Monastie
I guessed at your production date (8/91) on realoem.com.
It's M8/12 or 14 (8mm diameter) by either 12mm or 14mm long for the front rotor, or a M8/12 for the rear rotor.
Your local ACE hardware has a good selection of single metric fasteners in those yellow parts boxes.
1991 525i M50 5 Sp.
N.California
Use a 3/8" drive socket type Allen wrench to remove.Originally Posted by Monastie
You can usually break it free by tapping it with a hammer first to send a vibration through the fastener, before turning it out with the ratchet.
If that don't work, just use a sharp drill bit and drill the head of fastener off. Remove the rotor and whats left of screw should screw off by hand or pliers.
1991 525i M50 5 Sp.
N.California
