Most likely one of the two water valves for heating is stuck open. You can find this near the firewall on drivers side in the engine compartment.Originally Posted by The Melmaan
I have been dealing with this issue for a while now. Now the hot weather is here and I have to do some fixing.
The issue is there seems to be some warm to hot air blowing or coming from somewhere even when all the climate controls are off. It is so anoying are I don't even know where to begin.
Help, help help.....
2008 audi A3 1.9tdi
(former 1991 520i LPG)
sometimes i get this,i can ussually get the heater to go cool again by turning the heat up to full,and wait until HOT air starts flowing then i turn everything down to cool,if its still the same try again.But the real problem is a sticky(or stuck) heater valve
heater operation
Gone but not forgotten
I will second that. Check the fuse on the heater valve first, then if its not the fuse...pull it clean it. Not to bad a job only takes about an hour.
Much thanks to all of you guys. I will check this out this weekend....
