it almost takes voodoo to get it right with tape-a-weights on a older machine when you don't put the weights at the front edge (another reason i put the weights out at the edge ignoring aesthetics), the weight will never add up because you are changing the calculated position of the weight without changing the weight. the best advise i can give is use the setting where the machine puts all of the weights on the back (called static on my machine) and either put them on the back or in the center if you wanna play with it, if you wanna try a dual plane balance add around 25% to the front weight # it may still take a few trys as you are ****ing with the machines calculations
