Ethanol is known to cause higher fuel consumption because it carries less energy than gasoline. Thus, more fuel tends to be consumed to satisfy the power requirements of the vehicle. Its a double edged sword in a sense.
Since I got my car (1990 525i 5-speed) about a year ago, I had mostly filled up at Sam's Club (Wholesale Club) because the price was usually 10 to 20 cents cheaper than anywhere else. After I got a Dinan chip and started to use the higher octane fuel, I was a little concerned because the higher octane fuel at Sam's said it contained 10% ethanol. But I thought 10% can't have that much affect on stuff...
This past week I needed to fill up and Sam's was closed so I went to Shell and got the 93 octane (same octane as Sam's). The next day on the way to work I noticed an immediate improvement on the obc reading for mileage. After running through a whole tank (17+ gallons) and checking the actual mileage, I found that I got 26.2 mpg (US) with mostly highway driving. The most I EVER got before was 24.3 mpg. That's about an 8% increase in mpg's so I figure either the car hates ethanol or Sam's just carries crappy gas. With that increase in mileage and if gas stays around $3/gallon I figure I can pay over 20 cents more per gallon at Shell and still be ahead.
I know others have said not to use any ethanol because of other side effects, but I didn't really think it would cause that much difference. I'm guessing having the Dinan chip makes it all that more important.
Looks like I'll be going to Shell from now on.
I wish I could get non-ethanol gas around me. I notice a HUGE difference in my mileage. if I try, 29mpg versus 24mpg highway with ethanol. Not to mention the improved idle, response and power with straight gas. You are not alone.
Sam's is crappy gas
-Mike
Yep.Originally Posted by Sam-Son
What's that?Originally Posted by Alexlind123
EuroLux:. Private Detail
I agree about the less energy. I wouldn't have guessed just the 10% would make that much of a difference. So are the E-85 fuels going to be even worse, or are the engines made for running the E-85 tuned for the less energy which could bring the mileage back up some? If not, the E-85 better be a fair percentage cheaper than the regular gas to make up for it.Originally Posted by Rus
Unless you're really into helping the environment and willing to pay the difference...bring on the hydrogen cars!
Plus ethanol is corrosive and hydrophilic.
A bad idea brought to us by certain lobbyists and bought hook,line and sinker by the "greenies".
Milk is about to cost $4/ gallon now because the corn that used to feed cows is now powering some *******'s Escalade.
Some form of additive will be used in gas to reduce emissions whether it is ethanol or MTBE (methanol from petroleum). And gas retailers don't have to tell you when they use either as long as it is below 10%.
Alcohol absorbs water reducing corrosion (and ice in fuel lines). Gas tanks rusted out more often before it was added than after. And it's a solvent, not a corrosive.
There isn't enough farmland to supply all the ethanol needs/energy needs of societies with high standards of living.
Allowing only Commercial vehicles to weigh over 4000 lbs would go a long way towards reducing consumption. If Americans could move away from "Bigger is better" without adding regulations, that would be best of all.
Cheers,
Fin
