Per the Bentley, the cam at tdc (#1 cylinder) will have the dimple on the end of cam at 6 o'clock.
I got the bottom end together finally. but I want to put my head on. The head was not taken off at tdc...bad. I don't know how turn the head to make it at tdc for cylinder 1. The nut on the front of that is huge and all I have is a socket that goes till 36mm.. I really don't want to mess this up.. any advice?
erased due to slander
Mine was 36?
the 36mm was on the crank. I will look into getting a 42mm. Thanks for the help.
I was able to move it. The nipple is at six. Does it look right?
