Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: M60 Head Gaskets R&R - Parts List?
    Maryland
    Default M60 Head Gaskets R&R - Parts List?
    I've been having trouble lately and the reason turns out to be exhaust gases leaking into the cooling system... so it's time to do the head gaskets and a valve job.
    Aside from the head bolts and head gaskets, what parts do I need to tackle this job?
    Albany, NY
    You need a camshaft alignment tool. A guy on ebay sells them and and thats where I bought mine.
    http://cgi.ebay.com/ebaymotors/BMW-M...QQcmdZViewItem
    He is the only person I could find to sell them. Kind of expensive, but trust me you will need them.
    I bought my gaskets and head bolts from www.autohausaz.com
    I would recommend you should replace all your intake gaskets while your at it if you haven't done so already.
    You should also drop your oil pan to check to see if there are any oil pump bolts that have backed out.
    I made a thread on bf.c and there is lots of info in there.
    http://forums.bimmerforums.com/forum...d.php?t=608580
    Shoot me a PM if you have any questions about the process.
    Zac
    antifreeze and oil
    Maryland
    Thanks! I read your posts and checked out your pics and was impressed with the work you did.
    I'm smelling gasoline in my expansion tank so I may have a cracked head. I'll be sending them to a machine shop soon to find out what I'm working with.
    I located a camshaft alignment tool locally and lined up a torch to use on the header nuts. I also have a compressor so it should only take me a few hours to get both heads off.
    I'll keep you all posted and post some pics.
    Maryland
    I have two gallons of BMW coolant and a gallon of oil handy. Thanks for the advice.
    Jan 2005
    What Antreib said.
    95 E34 540i6 M Sport - 94 E34 530iT B40/6 - 92 E34 525i5 M52/OBD2 rip
    you need 2 gallons of oil.
    Quote Originally Posted by Evan
    Maryland
    i'll be sure to get another gallon
    Nashville, TN
    If you are getting that deep into the engine, go ahead and replace the valley pan while you are in there. I would say valley pan gasket, but that is no longer an option.
    The stone age didn't end for a lack of stones. Neither will the hydrocarbon age......
    Maryland
    the valley pan is under the intake manifold?
    what do you mean replacing gasket no longer option?
  1. parts list Alpina B12 5.0 and 5.7
    By shogun in forum 8 Series BMW
    Last Post: 10-08-2007, 02:32 AM
  2. Suspension Parts List help
    By txp135 in forum 5 Series BMW
    Last Post: 03-28-2007, 09:52 PM
  3. Parts list critique/help
    Last Post: 03-26-2007, 04:27 PM
  4. price/brand for M30 head gaskets?
    Last Post: 01-20-2007, 08:58 AM
  5. V12 top of engine, gaskets, seals + parts overhaul
    Last Post: 12-19-2006, 04:52 AM
