at the bottom of the seat back?
Not the part were you put your bottom onto, but the part where your back goes. I hve removed the 4 nylon nuts but I cannot seem to remove the seat. I have removed the 2 headrests and am making sure the seat belts are not in the way. I move the seat outward and try to push up but the seat isn't coming out. I've tried this with a helper also to no avail. I know I've removed it before when I installed by car stero stuff but it seems stuck now, i've tried for over 15 minutes removing this.
If my memory serves me correct, undo nuts at the base of the back near the squab and then lift/rotate the backrest. The top of the backrest is located by a metal loop resting on a notch in the rear bulkhead.
HTH
1997 e39 523SEi touring.
If you've got headrests you need to remove them and the plastic cover that sits on the top of the back rest. Then lift the back rest outward at the base so that its off the four mounting threads and then straight upwards.
Kris you also need to remove the plastic covers around the seat belts on top of the seat back. When doing this use a wide strong blade and lever upwards at front and back only - be real careful because the plastic is brittle, especially if its old. To get good leverage and avoid damaging the leather you could use a piece of thin hardboard underneath the blade.
Bill G Melbourne
