Interesting, what are you alignment settings?
Gives the front of the car a lot better turn in with better grip. it understeers a lot less now and the steering seems a bit heavier. i like heavier.
Martin is running them, so is stacey and Jeff N has talked about them also.
FS: PBR Deluxe rear brake pads [new]
Am I missing the point? From the photo you have not altered the static camber but the castor, and reduced it by a significant ammount.have a look at your wheels on full lock.Could be some interesting angles there! This causes the weighting of the steering which is what early M5`s had, but by design not modification.If it works good luck and let us all know where you got the plates/strut tops from.
The strut moves toward the engine, not fore and aft in the car.
Originally Posted by Barney Paull-Edwards
Bellevue WA
86 Porsche 951 - Track Toy
Anyone have a pic of the plates not installed?
These are the adjustables.Originally Posted by Jon K
Bellevue WA
Bellevue WA
is that plastic!?
.Originally Posted by BFEINZIMER
Bellevue WA
