But I had already powder coated a bunch of parts for this new motor and decided to do the other valve cover in silver, to match my parts. I got carried away with powder coating and cleaning stuff but this is the end result:
Now that school is done (never more!) I took the time to focus on this engine as I really want to make power and push the thing to the limit once I have a fall back car. I ordered all of the above parts in a couple phases, but the majority of the parts were collected about a month ago:
It was time to get serious with cleaning up the head and block so I could send them out to be machined.
We started with the cylinder head which looked like utter hell in as you can see in the very first pic in this thread, but after a couple hours of sodium blasting (again thanks to Jays having every tool under the sun), I was able to get it super clean. The only downside, I will say, to using a soda blaster is that the soda gets EVERYWHERE inside the piece. So, I have probably washed this head about... 4 - 5 times now. I am satisfied that it is clean, but yeah it's definitely annoying. Sand/bead blasting like we did with the other parts is not an option because you cannot afford to alter the finish/dimension of the combustion chamber and as I have experienced and no matter what anyone tells you, bead blasting DOES remove/alter material.
