Offset negative camber in lowered E34
Is there a front strut bearing and rear shock mount that will offset the negative camber of the lowered suspension in my 1992 BMW 525i E34 M50 non-vanos with Eibach lowering springs? I was thinking that perhaps the E34 M5 front strut bearing and rear shock mounts have offset for the lower suspension in the M5.
I currently have the Kmac kit in the front and rear. I am thinking about replacing them because I can't even replace a strut insert in the front without getting a major realignment. At least, I do not know how to. Besides they are squeaky in the rear.
Also, my Eibach lowering springs have over 100,000 miles on them. How long are they supposed to last? Would you recommend replacing them?
92 525i w/ Eibach lowering, Bilsteins, KMAC, Dinan chip, low temp coolant switch, K&N replacement air filter, UUC short shifter, RD strut brace, blacked out, 17" Borbets
