Thread: E32 750i brakes
    Victoria, Australia
    Default E32 750i brakes
    I have an opportunity to purchase the brakes off an 89 E32 750i, and I was wondering if these are a worthy upgrade for my 95 525i?
    Will it all just bolt across?
    Aden
    Old car: 95 525i, OB/Silver, Eibachs, Style 66, Missed dearly!!
    VIN Decoder | Online ETK
    | E34 Bible
    baton rouge, loserana
    the fronts will bolt up fine, but to get the vented rears you need the whole control arm as e32 rotors have a slightly different offset, doesn't effect the wheel just the brake, 28mm thick front rotors vs the 22s on e34s and vented rear rotors vs solid, same sweaped area
    had them on my 535 and they worked good
    ps, that's single piston front/rear calipers on our cars, not sure if the rest of the world got anything better, if so then do some measuring
    Victoria, Australia
    Thanks for the quick reply.
    These are the front brakes currently on my car: http://www.realoem.com/bmw/showparts...43&hg=34&fg=05
    Would the brake balance feel uneven if I upgrade just the fronts or shouldn't it be much or a problem since the rears are same size?
    Thanks.
    | E34 Bible
    Quote Originally Posted by t.wak
    Thanks.
    No you can keep the solids at the rear with no difference- you just get more heat resistance at the front. The 30mm rotors won't stop you any faster tho...
    just a few more times before they start getting stiff
    Quote Originally Posted by genphreak
    Victoria, Australia
    Thanks for the good info. The reason I was looking at upgrading was due to the fact that I will be taking the car to the track in November; so while the brakes need replacing I thought I'd look into upgrades.
    Cheers
    | E34 Bible
  1. FS 750i style 4's 16x8
    By Herb in forum 5 Series BMW
    Last Post: 11-25-2008, 11:37 AM
  2. 750i abnormal cranking
    By Eagle in forum 5 Series BMW
    Last Post: 08-22-2007, 09:08 PM
  3. Best place to look for a 750i...
    By CharlesAFerg in forum 7 Series BMW
    Last Post: 12-04-2006, 04:18 AM
