Results 1 to 10 of 18
Thread: Another E39 question
    Feb 2007
    GreenHills East-Philippines
    Default Another E39 question
    guys a little help.Friends e39 was overheating so we bled the rad still the same...checked and saw the aux fan was always in LOW mode and high mode will only kick in if the temp reached 3/4ths which is high! What we did changed the radiator, water pump , thermostat , and fan switch to 81/88'c...still the same. Aux fan will only kick in high mode if the needle reaches almost 3/4ths which is almost overheating. My e34 kicks in high just before the 12oclock position. any thoughts? thanks guys..
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Mar 2004
    NSW, Australia
    Check your temp guage against a known good unit..
    Feb 2007
    Quote Originally Posted by mamilapon
    will try to put in a diff.cluster to see if it changes. will let you know
    Feb 2007
    ok update, just installed a second cluster still the same. 3/4ths before aux.fan kicks in high.bled again still the same. Any ideas??
    Dec 2005
    Brisbane Australia
    Quote Originally Posted by bmwrp8
    i am not an expert but i'd be looking to see whether there is a high temp coolant switch that controls the aux.fan. and then seeing whether its working properly.
    something like no. 6 http://www.realoem.com/bmw/showparts...05&hg=17&fg=05
    Feb 2007
    Quote Originally Posted by rob101
    just changed the fan switch(80-88'c) in the side radiator still the same...I wonder if there is a second one...but i guess not.
    Dec 2005
    Brisbane Australia
    well maybe, there is a problem with electronic thermostat also.
    it shouldn't be going anywhere near 3/4 even if the aux fan is meant to kick in
    Feb 2007
    we've just changed the thermostat too. is there a second one? whats a electronic thermostat?
    Dec 2005
    Brisbane Australia
    hmmm i should have really read your first post :-P, no i am pretty sure there is only one :-P
    Dec 2005
    Brisbane Australia
    well you've kind of replaced everything but the fan clutch, which means It could be your main fan isn't cooling enough
  1. Replies: 1
    Last Post: 11-06-2009, 07:35 PM
  2. Fuel filter question and bumper question
    By 1995 525i in forum 5 Series BMW
    Last Post: 08-26-2004, 08:22 AM
