Originally Posted by
werminghausen
My driver side window doesn't work any more. It was never fast and the motor always had to work hard. Then it did not go down once in a while (It always went up- probably less resistance) but now it stopped working.
I can hear the click when I press the down button but nothing happens. The click is the same as if the window is closed and you push the up button. I think the click comes from the Relay Module (RM) or General Module (GM) but I don't know.
I heard that the GM does stop any window operation if more than 35 A are used.
Can it be that the mechanical resistance in the guides etc is too high that the motor can't turn? Is it a mechanical problem or an electrical problem?
Does anyone know? Martin
Wouldn't be surprised if the gears in the motor are shot - take it off?
On mine the motor/gearbox was bad and replaced as a unit.
Mine also had window actuator gears bent as well and I bought a replacement that was not OEM - big mistake, it wore out in 3 months....
07 525i 22K, 07 328xi (41K)
