Results 1 to 10 of 11
Thread: Rear sway bar Links-Help!
    Lexington, Kentucky
    Default Rear sway bar Links-Help!
    How in the do you get them on? I understand you lube and press them on. What type of "clamp" should I use. My drivers side is resisting a C-Clamp held with vise-grips. It is about 1/2 on with the sway bar rod almost through. Had to actually cut the old one off. Presently stuck. Help!
    Jun 2006
    Bethesda, MD
    First, my recommendation is to take a rotary brush or something and clean off the end of the sway bar (where the links go) REALLY well. I spent literlaly hours trying to push the damn things on with every kind of grip possible, even after cleaning them with a wire brush. Then I took my dremel out and attached a wire brush attachment and did a hell of a cleaning job. Then to my surprise with a very strong push and someone holding the sway bar (pushing towards me) it finally went on smoothly. Then did the same on the other side and it worked.
    Lexington, Kentucky
    Thanks for teh suggestion. Wish I had someone to help. Even so there was no rust or corrosion on the sway bar end. I did clean and lube and it is half on. Not why it seems to be hard to finish the job.
    Going out and see if I can find some sort of press or clamp that should work. BTW, a small tie rod puller would have pushed the old linke off the bar. However, I forgot I had one until after I cut the driver's side link off.
    Lexington, Kentucky
    I ended up using a 4" 2-jaw gear puller to "pull" the link onto the sway bar. I clamped a pair of vise grips to the bar for a "seat" for the pointed /center part of the gear puller. Took five minutes each. I hope the tri-flow oil I used for lube does not mess up the link's functionality
    hope it doesnt degerate the rubber...
    Quote Originally Posted by Russell
    Lexington, Kentucky
    I suspect the pressure pressing it on the bar squeezed most or all of the lube out.
    Jul 2004
    England (home) Germany (work)
    Just clean the surface, as suggested, and then soak the dog-bones/links in a bowl of hot soapy water, this provides all the lube needed and softens the rubber for a short while so you can just slip them on!
    As this is mostely an American forum, should i include a disclaimer warning about the possibility of burning from hot water or something!!...lol...
    Quote Originally Posted by nirvana19
    Lexington, Kentucky
    Quote Originally Posted by 525SEI BRIT
    Thanks for the advice. I sure wish I had done the softening bit with heat first. I just did not understand how much of a pain it would be before i started. I also did not know that the choice of lube was important, sort of like subframe bushings. BTW, no disclaimer necessary
    BTW, did your 95 540i come withe brake ducts or did you add them? In the US only the 94 540i came with brake ducts.
    Jul 2004
    Only meesin!!
    Did it work?!!
    To my knowledge all the UK and i think European 540's came with the ducts as standard, to distinguish them from the lesser engined cars. Can’t understand why you guys were robed of this feature, same as the rear headrests I guess!
    Dec 2006
    lesser engines!
    We got rear headrests in Canada, my 1991 525 has them.
  1. Meyle HD sway bar links
    Last Post: 06-19-2013, 10:35 AM
  2. seems irrational -sway bar links
    Last Post: 09-24-2007, 11:53 PM
  3. Help: Changing front and rear sway bar links
    By Alpinewhite in forum 5 Series BMW
    Last Post: 08-03-2007, 11:31 AM
  4. Replies: 0
    Last Post: 06-10-2007, 06:02 PM
  5. Symptoms of bad sway bar links
    By mbogosia in forum 5 Series BMW
    Last Post: 12-30-2005, 03:52 AM
