give mark a little time as he's usually busy and will get back to you when he gets your message, a check engine light is not normal
i installed the EAT chip, and now i'm getting a CEL. 1211 which e34.net tells me is "1211 DME Control Unit". Does the 540 eat chip throw this cel? is this normal?
the car runs fine, but i got a cel after a few minutes of driving, so i came home at low rpm.
edit: the engine performs fine, though i haven't been above 3000rpm. i called mark, no response. additionally, i tried swapping the stock chip back in and there was no cel, and then i reswapped in the EAT chip and the CEL was back.
thanks!
-Aurash
the car appears to run great; i think the problem is EWS related.Originally Posted by winfred
Hi Aurash,Originally Posted by MaloventEvil
I am not in my office, I am still in Vancouver till late Tuesday. I'll have to sort this out when I get home. I may need to read your stock chip.
Mark
URL: www.dsylva-tech.ca
Originally Posted by MarkD
hi mark! will it be safe to drive around with the new chip in? is this all just an ews or checksum problem?
thanks again!
you are safe, one prototype chip did that for me also, just a lean condition due to advanced timing, Mark will be able to whip up a cure to it hopefully soon.
I would try disconnecting/reconnecting the battery with the new chip in, but that's just me. Or else it could just be a bad firmware flash on the chip.
the reboot might help but im sure it rebooted when he removed the DME. Another thing that comes to mind is leaky intake, TB gaskets...Originally Posted by ThoreauHD
