Results 1 to 10 of 20
Thread: front end rattle
    Dec 2005
    VT
    Default front end rattle
    Hi:
    so far I have replaced the upper control arms and tie rod ends. I still get a rattle from the front end. Which bushings are still left that I can replace?
    Thanks for any input .........
    Derbyshire, UK
    Stabiliser bar (aka sway bar) links.
    1997 535i V8
    Quote Originally Posted by DaveVoorhis
    Yep,
    got rid of my rattle
    Dec 2005
    VT
    great .... thanks I'll order one
    Derbyshire, UK
    Why only one? Was only one side worn? They generally should be replaced in pairs, because if one is worn the other is probably not long for this world.
    1997 535i V8
    Dec 2005
    VT
    I thought it was one continous bar ... but now I see that they are a pair of sway bar links. Thanks for pointing that out to me.
    Mar 2007
    Liverpool UK
    I had a terrible front end rattle and i got rid of it by doing all these things:
    Lower control arms
    Upper control arms
    Sway bar links
    Tie rod assemblies
    Wheel balance + alignment
    1995 XJR: 4.0L S/charged straight 6 Auto
    What... It's not broken??? I can still fix it
    Dec 2005
    VT
    thanks ... what about the center drag link ..... does it haver bushings in it?
    Mar 2007
    Liverpool UK
    I'm not familiar witht the term drag link, but the centre tie rod has an idler arm that has a servicable bushing that could cause a rattle - might be worth checking. Jack it up, take the wheel off and look around... you'll see it.
    I've never changed one but i hear it is probably more time effective to change the arm rather than messing with the bushing for the difference in price.
    Dec 2005
    VT
    we're probably talking about the same thing, different names ...
    thanks again
  1. Front end Rattle
    By SKB in forum 5 Series BMW
    Last Post: 08-26-2008, 09:23 AM
  2. front end clunk rattle
    By edward in forum 5 Series BMW
    Last Post: 10-16-2007, 04:59 PM
  3. Rattle coming from front end
    By Al Gray in forum 7 Series BMW
    Last Post: 03-06-2007, 01:05 AM
  4. Front end rattle
    By guinness in forum 5 Series BMW
    Last Post: 05-08-2005, 07:04 PM
  5. Thanks to everyone! The front end rattle is gone!!!
    By CrimsonBrian in forum 5 Series BMW
    Last Post: 06-22-2004, 07:52 PM
