http://www.bmwe34.net/e34main/upgrade/Body.htm
You may have to order the terminals listed here and do some wiring
Hi All,
I have a 92 535i that has the non-ellipsoid fog lamps with 9006 bulbs. I bought some projector fog lamps that use the H1 lamps and discovered they use a different connector. Does anyone know where I can get a 9006 to ??? connector or the connector that BMW uses to splice in?
Thanks.
Another way to do it. Is to cannabalize some BMW two pin connectors and just remove the retaining clip that holds the terminals in and just use the black round terminals...just tried this last night
BMW sells a short wire lead with the connector on it.
I think it is # 61 13 0 007 442 "cable socket"
