Is the clutch really heavy now? and is that a good thing?
Clutch seems much grabbier and the pedal is SO heavy like a 3x pressure plate should be. The pedal feel now is 100% responsive and I can modulate it very nicely. I wonder if my slave was "on its way out" since I've had this clutch setup. I should be able to slip it a good amount on the way home (60 miles) and should be good as new I hope. If not, down comes the trans.
-Mike
supersized pressure plate = workoutOriginally Posted by Sam-Son
I'm not too up on the set-up you have but I would caution about making too much heat in the flywheel/clutch pack. I would hate to see you 'hot spot' the metal parts and end up with a chattery of a clutch.Originally Posted by Jon K
I take it you did not replace the clutch master cyl? When I was turning wrenches for a living, I recommended changing both the slave and master at the same time when either one failed. I had too many of the change only one jobbies come back within a couple weeks due to the other half of the system failing. It was a hassle for the customers to have the car towed in and brought the shop's integrity into question as the customers thought we failed to fix the original problem. Which in a way, I guess we did; at least until we started fixing both ends of the problem...
Brian
For equal time on the right leg, add a bunch of springs to the throttle return system!Originally Posted by Dave M
Brian
That plate should rattle like a bitch when pressed,dont slip it or, as somebody else said, you will distort the flywheel,good you found a difference, would have been a BITCH if that had not been the answer! If you can get hold of temp sensitive buttons , it pays to stick some on the rear or the bell-housing to keep an eye on max temps,paddle plate clutched do generate a fair bit of heat,GM/Holden water cool the bell-housing for that reason.
You know Jon, not even the title surprised me...
"Wow new slave made ALL the difference "
What else is new? Paid help that cheap now eh?
haha
Was it the actual slave that failed or did the slave just need to be bled well? Did you replace with the same size slave cylinder?
Brandon J
Slave filled - pissing brake fluid into bell housing/clutch slip/dripping out of crack between bell housing and oil pan
Replaced with same size slave
