Sport seats.....mmmmm
Anyone ever have this happen?
I push the "inflate" button and nothing, could it be the switch, is there something under the seat that could be bad?
I tried checking the fuses and they all seem fine.
THOUGHTS??????
1995 540i Manual build 1/95
There is nothing to inflate, it is just a motor which turns the support. Usual problem is that the lumbar support is seldom used/adjusted and motor gets stuck. Use a plastic hammer/mallet and hit the motor several times to get it lose again.
You say you have checked the fuses and that everything seems to be fine. Why not use a multimeter and check actually if their is power. Testing for facts is better than believing.
If such a DMM is too expensive, use a old bulb, solder 2 wires on it and that is your testing device for power, works great.
Bulb on = power o.k., no bulb on = no power.
Originally Posted by shogun
Sorry, I assumed it was air driven, but lowell has enlightened me otherwise.
I will be taking things apart today, hopefully.
Well, I took the back of the seat off and tapped the motor a couple times (per Shogun's advice) and SHAZAAM it's working again.Originally Posted by Keith
THANKS SHOGUN!
It was nice to see how the whole mechanism works, thanks lowell (Kalevera) for the write up and pictures, it helped me understand how this thing works, not "air pressure" its all mechanical.
I'm good to go for a drive now and my back won't be killing me!
WOO HOO!!!!!!!!!!!!!!!!!!!!!!!!!
From what I gather, lowell and Kalevera are the same person, lowell's name is in the pictures.Originally Posted by shogun
Here's the link: http://www.bimmer.info/forum/showthread.php?t=29635
Yes, same person.
For that pic I was looking for but could not find it to show you, thanks
http://img.photobucket.com/albums/v7...tx/lumbar1.jpg
My 535i lumbar support wasn't when i got it, turned out the harness connector contacts just needed a clean and she was all go.
