Results 1 to 9 of 9
Thread: Lumbar support not inflating....
    SF/Bay Area
    Default Lumbar support not inflating....
    Anyone ever have this happen?
    I push the "inflate" button and nothing, could it be the switch, is there something under the seat that could be bad?
    I tried checking the fuses and they all seem fine.
    THOUGHTS??????
    May 2006
    NH
    Sport seats.....mmmmm
    1995 540i Manual build 1/95
    There is nothing to inflate, it is just a motor which turns the support. Usual problem is that the lumbar support is seldom used/adjusted and motor gets stuck. Use a plastic hammer/mallet and hit the motor several times to get it lose again.
    You say you have checked the fuses and that everything seems to be fine. Why not use a multimeter and check actually if their is power. Testing for facts is better than believing.
    If such a DMM is too expensive, use a old bulb, solder 2 wires on it and that is your testing device for power, works great.
    Bulb on = power o.k., no bulb on = no power.
    SF/Bay Area
    Sorry, I assumed it was air driven, but lowell has enlightened me otherwise.
    I will be taking things apart today, hopefully.
    SF/Bay Area
    Quote Originally Posted by Keith
    Well, I took the back of the seat off and tapped the motor a couple times (per Shogun's advice) and SHAZAAM it's working again.
    THANKS SHOGUN!
    It was nice to see how the whole mechanism works, thanks lowell (Kalevera) for the write up and pictures, it helped me understand how this thing works, not "air pressure" its all mechanical.
    I'm good to go for a drive now and my back won't be killing me!
    WOO HOO!!!!!!!!!!!!!!!!!!!!!!!!!
    Glad it worked, but where is the write-up of lowell?
    SF/Bay Area
    From what I gather, lowell and Kalevera are the same person, lowell's name is in the pictures.
    Here's the link: http://www.bimmer.info/forum/showthread.php?t=29635
    Yes, same person.
    For that pic I was looking for but could not find it to show you, thanks
    http://img.photobucket.com/albums/v7...tx/lumbar1.jpg
    NZ
    My 535i lumbar support wasn't when i got it, turned out the harness connector contacts just needed a clean and she was all go.
  1. Lumbar Support switch
    By Bo525i in forum 5 Series BMW
    Last Post: 08-31-2008, 02:51 AM
  2. Lumbar support: Exec. alt. for $30.
    Last Post: 03-30-2007, 08:39 PM
  3. Upgrade: Adding Front Seat Lumbar Support
    By Kalevera in forum 5 Series BMW
    Last Post: 02-25-2007, 06:59 AM
  4. Lumbar support E34
    By BMW 5 SERIES in forum 5 Series BMW
    Last Post: 05-11-2006, 06:24 AM
  5. I've already got adjustable lumbar seat...
    By Martin in Bellevue in forum 5 Series BMW
    Last Post: 03-02-2005, 08:18 PM
